11-08-2023 04:31 AM
Can anyone help we have just recently installed a Nest 3rd Gen when installed the Electrician mentioned he could not switch off heat water although it was displayed on thermostat as off plus on the ipad. I read posts regarding this issue and switched Bacteria Prevention to off. The hot water is still continuing to be on despite our efforts even with lowering the temperature on the tank.Is this a fault on the Nest will it be resolved by getting a replacement ? We may resort to installing our original thermostat If all else fails.
11-09-2023 03:09 AM
Hi @Mascara , thank you so much for reaching out. I'm very sorry for any inconvenience caused by this. Can you tell me how many lights you see on the Heat Link?
11-11-2023 03:16 AM
Hi there, just checking in with you. Do you still need help?
