a month ago
When oh when will Google complet the functionality of this product? The API for hot water boost (UK model) has never been released so it isnt able to be controlled using Google assistant / Gemini or have automations set up
Come on Google, this is more useful to us than changing the temperature setpoint! I haven't ever changed the temperature setpoint manually since installing it, where as it gets got water boosted almost every day!!!!
4 weeks ago
Yes agreed, frustrating! Half baked as per usual. On top of the API - the hot water control should really be a separate device, not hidden away inside the thermostat settings. I want to have an easy boost button without going into the thermostat and setup an automation. Also an API will be handy
3 weeks ago
Thanks for posting in the community! I understand your frustration with the missing API for the hot water boost on your UK model. The inability to use Google Assistant, Gemini, or automations for this feature is a significant gap, especially since you use the boost daily. I'm here to help!
We appreciate your feedback. To ensure your request about this missing functionality is logged for our engineering team, please submit it directly using our feedback form. Your input is invaluable as we continue to improve our products and services.
If you have any questions, feel free to post them here in the forum.
Sincerely,
Juan
