12-26-2024 02:57 AM
Does anyone know if there is a way to change the increment timings to less than 30 minutes? So for example I could boost or set a hot water schedule for 10 minutes rather than the full 30 minutes. I have posted before a couple of years ago but it seems the thread was locked and no resolution or interest from Google? Any joy anyone?
12-31-2024 09:32 AM
Hi, @Xjacko!
Thank you for reaching out to the community and sharing your feedback. I understand your desire to set a shorter Hot Water schedule, specifically 10 minutes, instead of the current minimum of 30 minutes.
I recognize the importance of this feature for you and appreciate you bringing it to our attention. Currently, the Boost options for Hot Water schedules range from 30 minutes to 2 hours in 30-minute increments.
To help us prioritize the development of this feature, your feedback. is invaluable. Please share your thoughts and suggestions with us.
We are committed to continuously enhancing the features of the Google Nest Thermostat based on user feedback.
For further information about the Hot Water schedule, please refer to this article: Domestic hot water control.
Keep me posted.
Ana
12-31-2024 09:32 AM
Hi, @Xjacko!
Keep me posted.
Ana
12-31-2024 11:36 AM
Increments of 10 or 15 minutes would be really useful as I had this with my previous smart thermostat the 'Cosy' system. I was also able to use Alexa to turn the hot water on and off. With Nest you can only set the heating. Cosy was a much earlier smart thermostat so it is disappointing to have to loose 2 great features on a newer thermostat. Just needs a few lines of code adding surely?
01-02-2025 04:12 PM
Hi, @Xjacko!
Thanks for your quick reply! We really appreciate you sharing your thoughts on how to improve the hot water schedule. Your feedback helps us make Google Nest even better. To ensure Google receives your suggestions, please share them using the feedback form. Your input is valuable to us as we continue to improve the Nest thermostat features.
Feel free to reply if you have any questions.
Ana
