11-26-2022 05:04 AM
Please could someone tell me how I can override the hot water schedule without manually turning the hot water off so that it comes on again in the next schedule... for example if I have hot water set from 0800 - 1000 and 1800 - 1900 and at 0900 i don't need hot water on, how do i turn off the hot water without affecting it coming on again at 1800? All I can find is the On/Off setting under Hot Water, but i think if i change this to Off, it will cancel the schedule.... thanks Jackie
02-13-2023 07:30 AM
Hi, I'd like to know about this too, so I thought I'd reply to move it back to the top. Ideally there should be a cancel the next hot water schedule, but after lots of searching, I've not see a way to do this
