How to disable temperature keep changing
AJ29
How to disable temperature keep changing and when I in front of the thermostat it went back what I set up for neat 4 generation thermostat please let me know
moralesvicente
Hello AJ29,
Thank you so much for posting in this community. I’m sorry to know that the temperature on your Nest Learning Thermostat (4th gen) changes unexpectedly. Don't worry; it is a pleasure to be able to assist you.
I'd like to ask you a few questions to gather more information about the concern and find the best way to fix it.
  • When did the trouble start?
  • What other strange symptoms have you experienced since the problem started?
  • Are there any error messages? If so, what are they exactly?
  • Do you notice any intervals or specific patterns between these strange behaviors?
  • Does the trouble happen on heating only, cooling only, or both?
  • Are you using a schedule programmed in this thermostat?
  • Is this a new installation?
If you have any more information that could be helpful, please let me know.
Daniel
