Is my heat system compatible with nest thermostats?
Higinia
I'd like to know if my heat system is compatible, I currently have a dimplex heat pump system, that has a panel dashboard that controls 2 zones.
Eitanros
Hi @Higinia
Thank you for reaching out to the community. I understand you need help with the compatibility of your HVAC system. I'm happy to help you!
To assist you effectively, please provide the following information:
  • Do you already have a Nest thermostat? If yes, which thermostat do you have?
  • Please attach a photo of the current wiring configuration.
Please keep me posted,
Eitan
