My heat link is not working. No lights on and H71 on thermostat display. Where can i get a replacmen
Euphblower
AlexD
Hi @Euphblower , thanks for reaching out to us here. I would be happy to try and assist you.
If you have not already, check the breakers and switches at the location, to make sure nothing has tripped. Also check the boiler as it can sometimes have a separate switch on it. Confirm it has power, it should have a display or LED that turns on.
If it all looks good try and power cycle the Heat Link, if you're comfortable in doing so. Turn the power to the Heat Link off for a few minutes and then turn it back on. See if it has any reaction after when you press the button on it.
CristianC
Hello again. Just checking in. How's it going with your Heat Link?
CristianC
I haven't heard from you in a while so I'm going to lock this thread. If anything comes up, feel free to open a new one.
