01-14-2025 05:33 PM
Hello I recently just upgraded from the nest 3rd gen (had for several years now) to the 4th gen. The 4th gen is working fine but comes up with a low power error on the Home app and on the thermostat. I do not have a C wire only a W1 and RH wire (forced air heat). I have it hooked up the exact same as my nest 3rd gen was and I had no issues and no errors on the 3rd gen ever in the 4 years or so I've used it. Is the 4th gen more sensitive to the power or am I missing something. Other than the error, it seems to be working normally.
01-16-2025 01:31 PM
The 4th Gen thermostat draws more power than the 3rd Gen one.
A 2-wire heat-only system seems to always cause power problems and this is one reason I always recommend installing a C wire or the Nest Power Connector.
What type of heating system do you have installed?
