08-29-2024 09:15 PM
Purchased Neat 3rd Gen Thermostat less than 1 year ago for $300 at Home Depot. Very disappointed after seeing this post 3rd Gen Nest Learning Thermostat - Battery Issue https://www.googlenestcommunity.com/t5/Nest-Thermostats/3rd-Gen-Nest-Learning-Thermostat-Battery-Iss...
How can you sell this product that has no battery life span and you can’t replace the battery.
08-31-2024 11:19 PM
How do you have the thermostat wired?
Is there a C wire installed
09-04-2024 04:15 PM
@Patrick_Caezza Yes it is C Wired.
09-01-2024 09:43 AM
Yes there is a C Wire installed.
09-04-2024 09:58 AM
@Patrick_Caezza yes there is a c wire installed.
09-04-2024 04:27 PM
Do you currently have battery issues?
I'm confused.
Many people don't have a C wire install and will experience battery issues because of it.
Yes the Nest thermostats are designed to work without a C wire, but the real word truth is the power stealing that keeps the battery charged doesn't always work and only provides a partial charge to the battery,
