04-25-2023 03:17 PM
REPOST - @zoeuvre I was waiting for the issue to occur again, but previous thread was closed by time it did again. It just happened again. This time the heat was running, and I attempted to turn it down 4 degrees. This led to the outside A/C unit kicking on, and despite turning the unit thermostat to the off position, it continued to run. Only way to turn off was to turn off at breaker. I checked the history and nothing out of the ordinary was shown, only the heat running for around 2 hours per day.
__________________
Hello, I saw this discussed elsewhere, but I was not able to see a fix. This issue has been happening for over a year, and I have already had my Learning Thermostat swapped out once in case it was an equipment issue. It randomly occurs that when the heat is running, the outdoor A/C unit will also begin to run. Vice versa, in the summer, it also occurs that the furnace will turn on when the A/C is running. I've called about this issue a dozen times, and nothing seems to help. The wiring appears correct. It happened again today, so any help would be appreciated. Thank you.
04-26-2023 12:07 PM
Hi mattmono3,
Thanks for gettong back to us, and I'm sorry to hear what happened. I'd like to take a look at this for you.
Can you help me with a photo of your Nest Learning Thermostat's base where the wires are connected? Also, the reason why the last thread was already closed is because, as Community Specialists, we occasionally do a bit of housekeeping to keep the conversations in our community fresh and relevant. This includes locking threads after a period of inactivity.
Please keep me posted, I'm happy to help.
04-27-2023 11:59 AM
Thanks for your help! Sure, here you go
04-27-2023 12:46 PM
Thanks for the information. Let's try to do it this way by following the steps below:
Also, do the same thing of removing the W1 wire then calling for cool in the Nest Thermostat, then observe if the furnace will run.
04-30-2023 01:21 PM
Dan
05-01-2023 01:26 PM
Hey there mattmono3,
Dan
