01-29-2022 07:01 AM
Nest Thermostat Gen3 won't work with York furnace/thermostat that has A-wire. Called Johnson Controls & was told there is an adapter that makes my thermostat compatible with most 3rd party thermostats. Anyone know about this or how to obtain adapter?
02-03-2022 05:52 PM
Hey Patsyk9,
Sorry for the delayed response but thanks for posting.
If you're pertaining to a Nest Power Connector that acts as a substitute for a C wire, you can check this out: https://bit.ly/3z34z2e Otherwise, you need to contact OnTech Smart Services to check your HVAC system what specific adapter is necessary to have it work with our Nest Learning Thermostat.
Melba
