11-25-2024 03:29 PM
I have a Nest Thermostat (Information below) being used on a low pressure boiler system with a standing pilot control. The thermostat is configured for heat only with C-wire connected and verified 24VAC across the device for power. The thermostat randomly fails to initiate a heat command while the display states that the system is heating. I have verified that the control relay located in the boiler control unit does not energize under this condition. I have also verified that while the thermostat states it is heating, there is no 24VAC available at the W (Call for Heat) terminal with reference to the common (C)
Once I shut the thermostat off, wait 10 seconds, then turn back to heat, the thermostat then calls for heat (verified 24VAC between W and C) and the heat call relay is then energized in the furnace control. This is how I have verified the issue is with the device, not the wiring, power, or furnace control. Is there an update that can resolve this issue (as it seems like a software failure within the device) or is it time to replace the device?
Heat Configuration = Propane (LP) - Radiators
Model - Thermostat-1.4
Software Version - 1.3-10
Battery State: OK
battery Voltage: 3.08 Volts
11-26-2024 01:55 PM
did you happen to do a power test from the thermostat?
11-28-2024
04:46 PM
- last edited on
12-03-2024
11:52 AM
by
kevinmendez
Hi, @bkaufin52,
Thank you so much for reaching out to the community. I’m truly sorry the heating system is not turning on. I know how important a reliable heating system is, especially during winter. I’m happy to help you!
I really appreciate the detailed information you shared. To troubleshoot effectively, please provide the following information:
Also, please confirm that the wires are securely attached to the terminals. Ensure at least ¼ to ½ inch of the copper wire is exposed, straightened, and fully inserted into each terminal. If necessary, strip and reinsert the wires.
Best regards.
Ana
