05-20-2025 10:09 AM
Hi-
How does one turn on the fan using a Nest thermostat that does not have wifi (meaning, no app capabilities)?
When I use the options available on the Nest wall unit thermostat, none allow for scheduling or turning the fan to "always on", like the wifi app allows. Is this only possible with a wifi connection? Need to have the fan run continuously for next several months; there will not be a wifi connection.
Help. TIA
05-21-2025 08:52 PM
Try connecting the Nest to your phone using the phone's hotspot function, then set the fan how you want it, and then disconnect.
