12-22-2021 03:57 AM
Hi, 3rd Generation Nest Learning Thermostat Stand. One of the fixing screws is missing. Does anyone know where you can get them from, please?
12-22-2021 06:47 AM
Best option would be a DIY shop, it's a standard thread, just check the head size is small enough.
Where are you located?
03-23-2022 05:44 AM
Looked all over the shed and then the Internet for these screws orthis information. Did you get an outcome? I have the stand but no screws. Tried M4 machine screws but they are not right.
04-02-2022 07:14 AM
Official answer from the nest chat is "diameter 3.5mm and 13mm length including head". I cut down some M3.5 from UK electrical sockets and used a washer but you can find similar on ebay.co.uk item 234104165322 or (from Falcon) 201634955749. Hopefully 10mm is enough or try the 12mm at the same time. Good luck.
