Nest online and says cooling but unit not turning on.
MrsKnight
We unplugged our Nest device to paint the wall it was on. After reconnecting, it no longer cools the unit. There’s a stable WiFi connection, Nest says it cooling, and the fan is running outside. The indoor unit isn’t turning on though.
When you say you “unplugged “ you Nest Thermostat, you simply removed the display and did not disconnect any wires, Correct?
The Cooling Wizard
