Nest thermostat Battery not charging
Clkennedy51
Moved into a home with a nest learning thermostat. The battery won’t charge. From what I have read needs a C wire. There isn’t one 😵💫. Tried charging with the usb but doesn’t seem to work, can’t get a full charge , still low battery. How long should it take??? The thermostat can’t be more than 2-3 years old. What can I do?
Clkennedy51
Hello Clkennedy51,
I'm sorry to hear that your thermostat isn't holding its charge. I'm happy to help.
To isolate, could you tell us the make and model of your HVAC system? Do you have a heat pump unit? Also, please gather the power readouts under power from the technical info settings.
Checking back in — how's it going? Still need our help? Let us know so we can assist you right away.
Hi Clkennedy51,
I'm just checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
