03-19-2024 06:00 AM
I went through the installation and connected my wires where it said they should be and my forced air, which should only be on for circulating the AC turns on when calling for heat. I do not have an aux heat or dual heat system but the thermostat shows I do. I've uninstalled everything and repeated the process with the same result--
03-19-2024 06:33 AM
my old thermostat
Nest learning thermostat
03-22-2024 02:15 PM
Does anyone have suggestions?
04-03-2024 12:37 PM
Hi Daddyof3,
Sorry for the late response, but no worries, help is here. Checking your post, I noticed you have an O WIRE plugged in but according to it, you don't have a Heat Pump or Aux heat. Please try removing that wire and updating your wiring configuration on your thermostat performing a factory reset.
Let me know if that helps.
Axel.
