06-12-2023 04:28 PM
I have set a 7 day schedule for our Nest system. We have upstairs and downstairs units on different schedules. Eco mode is off and so is the Home/Away assist on both. Date and time are accurate. Yet, the thermostat won't follow the schedule. Why won't it work? TYIA
06-17-2023 12:51 PM
Hello abfonsy,
Thank you for taking the time to let us know about your inquiry. I'd be happy to take a look at this for you.
Is this a Nest Learning Thermostat? If so, please go to its Nest Sense settings to disable the Auto-schedule. This would only follow your created temperature schedule and wouldn't change the temperature on its own. Also, if you have the Google Home app installed on your phone, check the Routines and remove all thermostat actions available.
Let me know if that helps.
06-20-2023 03:07 PM
I'm checking back in. Were you able to do the steps above? I'd be glad to hear from you — I'd like to make sure everything is working.
06-21-2023 03:16 PM
Hi abfonsy,
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
06-21-2023 08:09 PM
I had done that all prior and no luck, but it seems to have gone to those settings since I originally posted my questions after a day or so. Thank you!
06-27-2023 12:35 PM
Hey abfonsy,
Thanks for getting back to us. I wanted to ensure that everything was covered here. How's it going? Were there any changes? If the same issue occurs, try resetting the thermostat to bring it back to its default settings.
Keep me posted.
06-30-2023 03:23 PM
Hello there abfonsy,
I don't want to be a nudge, but I'd like to check if you were able to get your thermostat working. Feel free to reach back if you still need help.
07-01-2023 04:03 PM
Hi there abfonsy,
