05-24-2024 06:36 PM
Please help my thermostat is not getting power in the Rh wire but if I remove the wire then the heat does not work. Since it doesn’t get power the thermostat battery dies and doesn’t work with google home because the WiFi disconnects.
05-24-2024 07:37 PM
How is the thermostat wired? Can you post a picture here?
Was it working before or is this a new install?
