No way to properly link thermostat with smart TRVs
hiemso
Hey,
I just had a quick look to the nest thermostat API and it seems like there is no way to properly connect smart trvs with the thermostat.
I was hoping to create a "orchestrator" between the trvs and the thermostat such that if a room isn't hot enough, I can signal the thermostat to turn on the heater. Seems like this isn't possible and I was wondering if there is any other way to do this task.
I tried to look online for alternatives but most of the responses seem to go unanswered or recommend going with tado instead of nest.
0 REPLIES 0
