Normal behavior? Fan turning on after heat
Tall_Guy_NJ
I just installed a new thermostat and I wanted to check to see if this was normal or what I need to do to fix it if it's not.
I have forced hot air.  When the thermostat turns the heat on, it runs for certain time, then it turns off.  About 10-20sec later, the fan turns on for a certain time.  It does it everytime.
Is this normal?
Tall_Guy_NJ
Bump
Hey Tall_Guy_NJ,
Apologies for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Hey Tall_Guy_NJ,
Glad to hear you were able to get the issue resolved. With that being the case, I am going to lock the thread at this time. If you run into any questions from here, please feel free to create a new post.
Tall_Guy_NJ
I worked with support and they resolved the issue with a replacement unit.
Thanks.
