12-15-2023 08:15 PM
My thermostat is about ten years old. It occasionally says power low and goes offline. Could it be at end of useful life? Do I need a new one?
12-17-2023 02:06 AM
Hi - that is a possibility but can you confirm how much power is showing for the thermostat in the Nest app (Thermostat)—> Settings (gear icon) —> Technical Info? It should always be at 3.85 V or higher for proper operation.
Do you have a C wire connection (usually a 5 wire harness) coming from the furnace/AC control board that you could connect to the Nest thermostat baseplate to give it sufficient power? Any issues you are experiencing at this time controlling your furnace/AC?
J
12-18-2023 11:16 AM
Thanks for chiming in, @jb76.
@TMcN12, uh-oh! If your ten-year-old thermostat is displaying frequent low power warnings and offline status, it may be nearing the end of its useful life due to electronic component degradation, potentially compromising the thermostat's performance. To check on the low power issues, gather the power readouts of your thermostat's Battery, VOC, VIN, and lIN under Settings > Technical Info > Power if you have the Nest Learning Thermostat or Nest Thermostat E and VIN, IIN, PS-* under Settings > Equipment, Power Info if you have the Nest Thermostat 2020. For your Nest Thermostat going offline, a few questions:
Keep us posted. We're happy to help.
