01-31-2023 02:33 AM
I recently moved înto another house i have a problem with the thermostat , i don t have acces to the pin and i can t Even restart it , what can i do about it?
01-31-2023 04:02 AM
Could you please explain which pin? It might help if you posted some pictures even
01-31-2023 06:22 AM
This pin ..
02-05-2023 11:12 AM
Hi IonelaDumitr,
01-31-2023 07:13 AM - edited 01-31-2023 07:19 AM
Ah! You can unlock the Nest thermostat in one of several other ways.
With the Nest app
Open the Nest app and:
With the Home app
Open the Home app and:
Note, though, that these both require that you have access to the Nest Home, and/or thermostat is linked to your account (or shared with you).
01-31-2023 07:26 AM - edited 01-31-2023 07:26 AM
Since you just moved in, it might not even be connected to wifi though. In that case, you will need to contact nest support and follow these steps
02-02-2023 10:59 AM - edited 02-02-2023 11:02 AM
@IonelaDumitr , I saw your post and wanted to chime in.
To unlock the Nest Learning Thermostat you need to connect it to a computer using a Micro USB cable and check for a file named TechnicalInfo.PLIST. Also, you can try to contact the previous owner for the PIN.
Thanks @jtbg and @Zouf for your help.
01-31-2023 09:15 AM
Having gone through a set of similar issues in the past (taking over an apartment with a bunch of “smart” devices without any info from the previous occupant), I do think the absence of a reset to factory default without the intervention of Google support is far from great.
02-06-2023 11:28 AM
Hi IonelaDumitr,
