Problems with Nest thermostst
thisisme6423
I have a Nest thermostat.  What a piece of crap!  It automatically and without authorization changes the password, I know that because I write down the password each time I make a new one. Then when I try to re-set the password it refuses to let me do that.  Don't buy this device you will be sorry.  I am ready to tear it from the wall.  Also there is no tech support.  Can't contact the supplier and the on-line assistance is completely useless.
Jhonleanmel
Hi thisisme6423,
Thanks for posting and sorry for the inconvenience this has caused you.
The Nest Thermostat does not have the capability to change the password on its own. Could you tell us what message are you seeing on your thermostat's display?
Mel
Hey there thisisme6423,
Mel
EmersonB
@thisisme6423 just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
I appreciate the help, Mel.
