Re: Heating problem
cathyj528
I'm having the same issue.  I turned the heat on for the 1st time this season and I'm getting cold air.  Anybody have an suggestions?
luciaaa
Hi, @cathyj528!
Thank you for reaching out to the community. I'm truly sorry your system is giving cool air instead of heating; I understand the importance of the system working properly, especially during the winter. I’m happy to help you!
To troubleshoot effectively, please answer the following questions:
  • What type of thermostat do you have?
  • Do you have a conventional or heat pump system?
    • Conventional System: Typically consists of two pieces of equipment (furnace and AC).
    • Heat Pump: Handles both heating and cooling with a single unit.
  • Would you mind sharing a picture of your wiring configuration?
  • When was the last maintenance check for your HVAC system?
  • Have there been any recent changes or upgrades to your HVAC system?
  • Does the issue happen with heating only, cooling only, or both?
  • Are there any error messages?
In the meantime, ensure wires are fully inserted: The wires may not be making a proper connection with the terminals. Make sure at least ¼ to ½ inch of the copper wire is exposed, straightened, and fully inserted into each of the required connectors. If necessary, strip and reinsert the wires.
For additional troubleshooting steps, you can refer to this article: Troubleshoot strange heating or cooling behavior.
Ana
