Nest Temperature Sensor setting for Farenheight/Celsius?
GunnyKing
My Nest Learning Thermostat is setup in Farenheight.  My Nest Temperature Sensor is setup in Celsius.  How do I change the Sensor to Farenheight to match the Thermostat?
2 REPLIES 2
Ashepherdson
Seems to be an ongoing issue, I will escalate this to the team for you, also feel free to leave feedback through the Google Home app about this as well!
gmelanymelissa
Hi @GunnyKing,
Thanks for posting here in the community. I understand your concern about changing the Nest Temperature Sensor to Fahrenheit to match the Nest Thermostat. I'm happy to help!
To better understand the situation, I'd like to ask a question:
  • What generation Nest Learning Thermostat do you have?
  • Are you using the Google Home app or Nest app?
In the meantime, let's check this tip:
@Ashepherdson, thanks for your help, that's a great resource for everyone!
Keep me posted.
Melany
