Heating problem
Markall007
Hi
Not sure what neat I have but I’ve turned my heating on but have no heat ?
luciaaa
Hi, @Markall007!
Thank you for posting in the community. I'm sorry to hear your system isn't heating; I understand you need it working properly, especially with the low temperatures. I'd be glad to help!
To troubleshoot effectively, please answer the following questions:
  • What type of thermostat do you have?
  • Are you located in America or Europe?
  • Is the Nest thermostat newly installed?
  • When does the inconvenience start?
  • When did the heating last work?
  • When was the last time your HVAC received maintenance?
  • Have you experienced extremely cold weather lately?
  • Is it displaying any error code?
  • Do you have an air conditioning system? If so, are the fan and AC running properly?
Additionally, please provide the following information:
  • A picture of the current wiring configuration on your Nest Thermostat.
  • A picture of the configuration on the Nest or Google Home app.
This information will help to determine the best next troubleshooting steps.
Thank you for your cooperation. I look forward to your response.
Best regards.
Ana
