Replacement for Nest Learning Thermostat (2nd gen) - Wireless or Wired Smart Thermostat X
Colum
What is the best replacement for Nest Learning Thermostat (2nd gen) if you had to choose between a Wireless or Wired Smart Thermostat X?
Planetxx
The best replacement is not to ever buy another Nest product, they are going to force you to replace it every few years now! Don’t get caught up in the google ripoff
