10-15-2021 08:41 PM
The system (learning thermostat) is heating instead of cooling and vice versa. I'm pretty sure the wiring is correct. I even went as far as to swap the cooling and heat wires. That still did not solve the issue. Has anyone experienced this issue and if so how did u resolve it.
I have Y1 (yellow), G (fan), W1 (heat) Blue (24V common), RH(power). Do I need a jumper for RC to make this work?
10-15-2021 08:48 PM
Ok. I just read that the RC and RH are internally jumpered. So that's not the issue. Still looking to resolve this issue.
11-23-2021 11:42 AM
Hey all,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
11-24-2021 11:51 AM
Hey all,
It has been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions, please feel free to create a new post.
10-23-2021 09:01 AM
I have the same issue. Have they helped yet? I can't get any help at all.
11-18-2021 10:56 AM
Hey all,
Apologies for the late response. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
