04-17-2024 03:53 PM
Heat on my thermostat has worked fine when I transferred from Honeywell to Nest, but When i switch to cool mode the Air conditioner works but it still activates the blower on my Furnace. How do I avoid this?
04-20-2024 04:56 PM
It sounds like your Nest thermostat might be configured incorrectly for your HVAC system. Here are some steps you can try to prevent the blower from activating when using cool mode:
Check Nest Thermostat Settings:
Here's an article that can help you with more advanced fan control options for your Nest thermostat: Fan control with a Nest thermostat
Please try these steps and let us know if the issue is resolved.
All the best,
Josh
