12-14-2021 08:11 AM
The thermostat will not register with the app because it can not connect to wi-fi due to low battery. It is a wired gen 3 and has not had this issue in the past 3 years. It is automatically supplied power when on base, but does not seem to be charging. This seems to be a common problem, but I can not find a solution in past posts, not can I reply to a thread. Is there is a solution other than replacing it?
12-14-2021 10:13 AM
Having this exact problem. Our issue was the nest heat box (white box) fault. They are sending us the part within 2 days. They answered really quickly - 0808 169 2307
12-15-2021 07:02 AM
Sorry if it is obvious, but what or where is the heat box?
03-12-2022 05:13 AM
How do I contact them?
