08-25-2021 10:41 AM
Original Poster: Linda Kronsberg
I keep deleting scheduled scheduled times which I never set up I don't want my temperature switching times at all I want it set where I put it why doesn't keep changing times by itself it is really irritating me
08-25-2021 10:42 AM
10-05-2021 08:16 PM
The solution you have proposed has not worked for me. Too much AI/ML going on here and the algo is not correct. It’s hot where I live, I set my nest thermostat to 71 and want it to stay 71 until ‘I’ change it. I wake up in the middle of the night due to heat and see that Nest has changed my setting to 75. I suggest fixing the buggy software so people have full control and manual settings should completely override your software. Any other ideas as how to fix this problem verses resetting/rebooting the device. This is done when there’s a software problem…
