Wiring question - power adapter?
MarkBorenstein
I'm trying to connect my new Nest to our HVAC system. But the letters corresponding with the wires doesn't match up with what the Power adapter suggests. When i connect the wires directly to the Nest, it allows me to control the HVAC system but comes up with an error stating i should use the power adapter. How would you recommend i connect the power adapter to these wire leads shown below?
G = Green
R = Red
Y = Blue
O = White
catheryn
Hi @MarkBorenstein
Thank you for posting in the community.
I understand you have some questions about the initial wiring setup for your Nest Thermostat. Don't worry, I'm here to help.
Before we proceed, please share a clear picture of your current wiring.
In the meantime, you may find this link helpful: Thermostat compatibility checker. It provides visual guidance.
Please let me know how this goes, and we'll assist you further.
Catheryn
