heat pump and condensing boiler
bbuchanan74
Hi All,
I currently have a two stage heat pump with aux heat as well as a hydronic condensing boiler that only heats baseboards, no coil in air handler. the electric heat strip is set for aux and the boiler is set for emergency heat. currently wired as, Y1- Heat/Cool, G-fan, OB- Heat pump, RC- power, W1-alt. Heat, C- 24V common, *alt. stage/ emergency heat. The issue i am having is the air handler turns on when the emergency heat setting (boiler) is turn on. I am not sure if the thermostat is wired incorrectly or something else. Also i noticed when i switch the thermostat to emergency heat mode the room temperature jumps up about 5 degrees automatically. why would this be? Any feedback would be greatly appreciated. Thank You!
RenzJ
Hi bbuchanan74,
Thanks for bringing this up. I understand they can be confusing, but no worries, we'll check this out.
We might need to update your settings or do a setup again to make sure everything is aligned, but before that, please answer the following:
  1. Are you from North America or Europe?
  2. What type of Nest Thermostat do you have?
  3. Send us a picture of the current wiring and, if possible, the old wiring before the Nest Thermostat.
  4. What is the make and model of your heatpump?
Renz
1. From North America.
2. 3rd gen learning thermostat
3. picture attached
4. BOSCH condenser model# BOVA-36HDN1-M20G. Air handler: BVA-36WN1-M20
RenzJ
Hello bbuchanan74,
Thanks for the update.  it seems like the photo was not sent to this thread. Go to this link Google Nest Community Forum. Hit reply on the thread,and you'll see a camera icon or three horizontal lines to expand the toolbar, where you can click the camera icon and send your image.
Renz
