05-08-2024 01:41 PM
Water is only being heated when the boost option is chosen or when the central heating is on at the same time as the hot water schedule.
A heating engineer has checked the other parts of the system and has found no faults. He therefore believes it is a problem with the nest thermostat.
What should I do?
TIA
05-11-2024 04:05 PM
Hi keith2511,
Thank you for posting. I'm sorry that the heating doesn't activate per schedule. Help's here.
For this concern, please review the following article to check the settings of the domestic hot water control to troubleshoot the issues.
Let me know if you need more assistance.
Byron
05-11-2024 10:27 PM
Why have you advised that action when I stated in my original post that a heating engineer has already checked the other components of the system? Why?
05-13-2024 08:13 AM
Hi keith2511,
Thank you for posting. I understand an engineer already checked your system; I provided a link with steps to check the settings on the Nest app.
Did you try the above steps? There are a series of options to check about the schedule of the thermostat.
Please keep me posted if it works.
Byron
