09-27-2023 12:02 PM
I've had this issue for a while.
your thermostat needs to shut down to recharge its battery
I get this message just after the thermostat shows the home logo and then goes off.
I can not do anything with the product to get into settings it will stay on for maybe 10 seconds. I'm at a loss what needs to be done it may need replacing? Any help welcome
10-11-2023 10:30 PM
Good morning
This has now been resolved. I had tried all of the above a few times but still nothing changed. In the end I spoke to the help chat online and got a replacement.
All is working great now. One thing I would say is you have to reset the heat link a load of time for the display to connect to it but it does in the end.
09-30-2023 05:48 PM
Hello blackaces,
Thanks for reaching out to the Community.
I’m sorry to hear that you're having issues with the Nest Learning Thermostat. Let’s check it out.
A few questions: what country are you located in? Is this a new installation? Did you notice any error codes on the display? Also, are there any recent power outages or electrical work done in the house?
Please try the steps below:
Here’s a guide on how to troubleshoot when your thermostat won’t turn on.
Let me know how it goes.
Lance
10-11-2023 03:08 PM
I am also having this issue. The thermostat is less than a year old. I have removed and charged it to no avail. Wasn’t having this issue until about 8 months in.
10-11-2023 04:55 PM
@MiraTera, thanks for being a step ahead of us. To confirm, were you able to try using a different charger or charge it directly to the power outlet? Does your Nest Thermostat have any blinking light? If yes, what is the color of it?
@blackaces, I just want to check if you managed to see and try the troubleshooting steps listed above. Please let us know how it goes.
I appreciate the help, Lance.
10-12-2023 05:22 AM
I tried a different charger. No blinking light.
10-11-2023 10:33 PM
Good morning
If youve tried all the troubleshooting and nothing has changed like myself. Get yourself in touch with the help desk chat and they go through it with you and if it's like me they will replace the unit.
10-11-2023 10:30 PM
Good morning
