10-22-2023 10:03 AM
I have 3 Google nest wifi pro devices which are having issues as of 2-3 weeks ago. I have 50-60 devices connected to the Wi-Fi or hard wired. Lately, I can get the 2.4ghz only devices to connect to the Wi-Fi but they will disconnect after about a day. I have to reboot the system to get them reconnected to 2.4ghz before or happens again. I unplugged the 1 point that was closest to the majority of 2.4 devices to see if maybe they were trying to connect to 5ghz. It worked for a day, then all the 2.4ghz devices are no longer connected. I have 1 day left on my warranty, tried to file a claim but it does not come up in my "home" on the warranty checker even though much older devices do and I can see it in my Google store purchases.
10-25-2023 12:43 PM
Hi dalester,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Which Google/Nest router are we working with? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem?
You can do a sequential reboot of your entire network and see if that helps.
or
Please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
