01-29-2024 12:12 PM
I currently have a Google Nest Wifi Pro mesh system using a total of 5 Pro routers, including the main router (1 main router plus 4 extenders), all using wired backhaul for the mesh network. I would like to add a 6th, or possibly even a 7th, Pro router, also using wired backhaul for the mesh network. I have read that only a total of 5 routers are recommended, otherwise performance declines. My question is, if I'm using wired backhaul for the whole mesh system, would I still run into problems adding additional Pro routers to expand my network coverage?
From the Google Nest Help Center:
We recommend a maximum of 5 Wifi devices in a single network. Adding more might be detrimental to Wi-Fi performance.
01-29-2024 12:35 PM - edited 01-29-2024 12:36 PM
I just received this response from a Google Nest Advisor on Google's Help site:
Hi Jacfer,
Thank you for getting in touch today. My name is Dérek. I’m a fellow customer like you, and I’d be happy to help you today with your query.
PS. You can step away if needed and always continue with this chat by clicking on the link that’s been emailed to you.
This recommendation is only for network created via Wifi only.
But in your situation where the router is connected by the cable, then this restriction does not apply.
Yes, you can connect, without problems 😃
Hi Jacfer,
02-04-2024 05:18 PM
Hi Jacfer,
You're right that Google officially recommends a maximum of 5 Nest Wifi Pro routers in a single mesh network, regardless of whether you're using wired backhaul. While wired backhaul generally improves performance and stability compared to wireless backhaul, exceeding the recommended number of routers can still lead to issues.
Here's why adding more than 5 routers, even with wired backhaul, might not be ideal:
Potential Issues:
Alternatives to Consider:
While exceeding the recommended number of routers with wired backhaul might not immediately cause major problems, it's not officially supported and comes with potential drawbacks. Carefully consider your specific needs and constraints before deciding to expand your network beyond the recommended 5 devices.
I hope this helps. Also, since you've been in contact with our team (chat or call), do you have a case number that we can review?
Dan
