a week ago
Last week on November 13th all my points went offline and haven't come back since. I haven't made any changes or touched anything. Last night I tried powering off and powering on all the devices which didn't work. I also tried to factory reset one and re-add it. The Home app saw it and had me scan the QR code and played the tone, but when it got to where it was connecting to my wi-fi network it wasn't able to.
Other devices including my computer and phone are connected just fine. In the Home app I can see the other points that haven't been reset, they say offline and have an ip address when I look at their settings but the ip doesn't ping from another device on the network.
What can I do to get my points back?
Thanks!
a week ago
I am having the same problem.
a week ago
I have same problem!!!
Friday
Hello @jschilen,
Thank you for posting in the community. I understand that you experienced a failure of your Google WiFi points, with all points dropping offline on November 13th and remaining offline since then, and that you have already tried powering off/on all devices and even attempted a factory reset and re-setup of one point. Let me help you with this.
The fact that all points failed simultaneously and a factory reset point failed to reconnect to the network strongly suggests a fundamental issue with the main router's connection to the modem or a widespread system firmware error that a simple power cycle couldn't clear.
We need to perform a comprehensive restart sequence to force a fresh connection between your ISP, modem, and the Google WiFi router.
Step 1: Complete Power Isolation and Reboot
This sequence is crucial for resetting the network address delegation and clearing any cache conflicts.
Step 2: Re-attempt Factory Reset and Setup
After the main router is confirmed stable (solid light), reattempt the factory reset and setup of the point you were working on previously.
Let me know how it goes and keep me posted.
Kevin
Saturday
Hello Kevin,
Thank you for that comprehensive plan. I unplugged my router (even both network cables), wifi points, and modem for at least 20 minutes. I also used the Home app to factory reset the entire network. I was able to re-create my wifi network and my laptop, phone and other devices are back on it. However when it got to the step of adding the points they again were discoverable, and I went through the process of adding them, heard the chime but when they try to connect to wi-fi it just says "Connection problem during setup. Please check your Wi-Fi network settings."
Jeremiah
Saturday
I did everything you said and what all other posts said!!!! My devices aka speakers will not connect! Yellow light!!! Extremely frustrating wasted 3 hours out of my day doing it multiple times!
Saturday
Hello there,
Thank you for trying the comprehensive power isolation and factory reset steps and for providing the update. I understand that you were able to successfully re-create your main Wi-Fi network using the primary router, and your laptop and phone are now connected, but the secondary points still fail to connect during the setup process. Let me continue helping you.
To determine why the points cannot connect to the primary router, I need to clarify a few details about your system and the steps you have taken:
Please provide the answers to the probing questions above so we can isolate the cause of the connection failure.
Kevin
Sunday
1. I tried a manual factory reset on two of the points before resetting the router. This morning I tried a manual factory reset on one of the points and tried adding it again. It again failed.
2. Yes.
3. No there is no conflict. I turned off the wifi on the ISP router.
Jeremiah
Monday
Why would any of this matter if I didn’t touch anything and it just stopped working?
Monday
Did everything you asked still no connection to speakers!!!!
