09-12-2022 11:01 PM
Pretty much as the title says. I assume it's trying to connect to the 5g band and not the 2.4g band as it should, but whatever system it's using is throwing up an error. All other devices connect fine to the Nest. This printer is the oldest device in the house though. Still sucks that it won't connect.
09-19-2022 11:14 AM
Thanks Jeff. I ended up just replacing the printer. It seemed the overall path of less trouble.
Thanks.
09-13-2022 06:16 AM
If it had an ethernet port (RJ-45) you could use an ethernet cable. But it does not seem to have that, according to the specifications.
Workarounds you can try:
09-16-2022 09:06 AM
Hi PaulS333,
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
09-19-2022 10:34 AM
Hey PaulS333,
I'm just checking in once more to see if you still needed some help here. If so, just let me know.
Jeff
09-19-2022 11:14 AM
Thanks.
09-19-2022 12:22 PM
I'm glad you found a solution, PaulS333. That's always great to see and I hope that works out perfectly for you.
Before I mark this as resolved, is there anything else you might need?
Jeff
09-22-2022 07:05 PM
Princess
09-23-2022 07:30 PM
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Wifi and we'd be glad to assist you further.
Princess
