03-27-2024 05:18 PM
Hi, here is my setup:
Modem (not router combo) > Wifi Pro router > unmanaged switch > Windows PC
When I was using my Google Nest Wifi router in this configuration, I had no issues. Today I upgraded to a Nest Wifi Pro and now everything on the switch is capped at 100 Mbps. The router itseld and wifi connectivity does not have this cap.
I'm using all of the same cat 6 cables and switch that I used with my Nest Wifi. The only thing I changed out was the router.
I've already tried the troubleshooting tips from this thread, but it didn't resolve the issue:
I also tried moving cables around to differnt ports on the switch, but the issue is on all of them. All ports are 1Gb both ways, though.
Switch: NetGear GS108
Modem: Spectrum PC15 D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem
I suspect that the Wifi Pro is simply not compatible with some equipment out there and that I need to initiate a return, but it would be great to have confirmation. Or maybe if it is known that the switch is what it's not compatible with, perhaps I could find another one to replace this.
04-04-2024 01:25 PM
I have now solved my issue. I have 2 flat, black cat6 cables that are identical in appearance and length, except what's printed on them. One goes from the switch to my PC, the other goes from the switch to my security system.
When I had set up the new router, I must have switched these two cables without noticing, because after swapping them out now, I'm no longer capped in speed on my PC. I figured this out when I bypassed the switch and was able to get 500 Mbps.
03-30-2024 01:25 PM
Just wait until you run into the port forwarding problems with wired connections. Its super fun.
04-04-2024 01:25 PM
