10-13-2022 07:43 AM
I know it's new and not released yet but I've looked everywhere and can't find the answer. My ISP uses Plume HomePass and I'm thinking of switching to the Nest Wifi Pro to avoid the rental fee through my ISP.
I wanted to find out if the Nest Wifi Pro will automatically switch between all 3 bands or if you'll be able to manually set each device to which band you'd like. I'm asking because I don't want our Nest Doorbell or cameras going in and out of connection due to the automatically switching.
10-13-2022 08:30 AM
Hello @MortgageMan90
In WiFi (in general), client devices make their own decisions about which access point and which band to connect to initially as well as when to switch between them. Google/Nest WiFi (including the new Nest WiFi Pro) support some optional standards (802.11k and 802.11v) that they use to provide clients with extra information to help them make better decisions. This information includes things like telling them which other access points are part of the same network so clients know they can switch without losing any open connections. It also includes signal quality measurements from multiple access points and bands so that clients can tell which other options might be better than what they are currently connected to. The new Nest WiFi Pro should support all three bands for this extra information to help clients that also support 6GHz make good decisions about when to switch between them.
But, these standards are most useful for mobile devices, since fixed devices should just be scanning and selecting a good option when they first start up and then sticking with it. So, most fixed devices don't support these standards, and make initial decisions on their own. Some do a better job of this than others, unfortunately.
Long story short, while the network can provide some enhanced advisory information, decisions are ultimately left to clients.
I will add a caveat that some WiFi networks attempt to be more aggressive about getting clients to switch by literally kicking them off of a band/access-point. This can have unpleasant effects, and may or may not actually help. I don't know whether Google/Nest WiFi does something like this, but I would be surprised if it did. It's mostly something done in enterprise networks that deal with more mobile devices, some of which do not support 802.11k and 802.11v.
I know this was probably a lot more detail than you wanted, but this stuff is a lot more complex under the covers than the simple marketing descriptions imply.
10-16-2022 11:09 AM
Thanks again for helping here, @MichaelP.
@MortgageMan90, I hope you've got the answer you're looking for. If you're still in need of any assistance, feel free to let us know.
Mel
10-17-2022 05:25 AM
Yes! Everything is good. Thank you for y'alls help!
10-17-2022 10:11 AM
Hey MortgageMan90,
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
10-17-2022 10:25 AM
Nothing else at this time! I'm working on handling a Double NAT issue with my ISP but that will be resolved this week. Thanks for everything!
10-17-2022 10:43 AM
Hi MortgageMan90,
You're welcome. As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread now.
Mel
