Google Nest Pro - Ethernet port Bandwidth less that directly connecting to ISP ethernet port
jprop1
I just purchased the new Google Nest Wifi Pro 6e. My current issue is with the Google wifi router ethernet port. Connecting to my ISP ethernet port directly and testing the bandwidth, i am getting over 900k down / 40k up. When I plug the ISP to the Google Nest using the same CAT6 cable, and test at the ethernet port on the Google Nest, I am getting less than 200k down / 30 up. Is there a setting on the Nest that is preventing the maximum bandwidto pass through? I have two CAT6 cables and have swapped around to ensure one is not bad. They are both functioning just fine. It's only when I add the ISP via the CAT6 cable to the Nest is when my direct connect to the ethernet port is limited to lower bandwidth.
Dan_A
Hi jprop1,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Are you connecting your computer to your Nest Wifi Pro by using the LAN cable? Have you tried other devices?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
  1. Disconnect the power from the modem.
  2. Disconnect the Ethernet cable and power cord from the parent point.
  3. Disconnect the power cord from the child points.
  4. Leave everything unplugged for 2 minutes.
  5. Connect the power cord to the modem then to your router and points.
Let us know how it goes.
Dan
jprop1
Hi Dan,
Thanks for the follow-up response to my concern. The problem has been resolved. I did factory default the entire system and started from scratch. After reconfiguring the Google Nest Wifi 6e router, the speedtest / bandwidth from the ISP is now clocking 900Mbps down/40Mbps directly connecting to my laptop. Not sure what happened but it is working great now.
Alex_S
We’re glad to hear that this has been sorted out. Thanks for keeping us posted! Should you need further assistance, you know where to find us. We’d be more than happy to assist you.
Alex
