06-01-2023 04:28 PM
I've seen versions of this issue before, but I've yet to see a definitive solution. Wired speeds to desktop computers/devices are generally pretty fast, but my wifi is usually around 10% of what it should be (I have Xfinity cable internet with a brand new owned Motorola router). The Google Home app always shows my speed in the 400-500+ Mbps range, while Speedtest (and my own user experience) shows far lower...around 40. I have version 1 Google wifi as well as Nest wifi. I've tried different combinations of those and nothing seems to work. Sometimes restarting the system works, but it usually reverts to slower speeds eventually. Recently even restarting isn't working. Does anyone know of a solution?
07-26-2023 05:14 AM
Hi darrenmassa,
I’m sorry to hear the trouble with your WiFi speed. Let’s further look into it. Just to check, what’s the distance of your Google Wifi and Google Nest Wifi from each other? The placement of your Google Wifi/Nest Wifi is vital for the reliability of your Wi-Fi network throughout your home. Kindly visit Where to place your Wifi devices. If the issue persists, try doing the troubleshooting steps below:
Let us know how it goes.
Alex
07-29-2023 09:53 AM
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Alex
07-31-2023 07:11 PM
Hey darrenmassa,
We haven't heard from you in a while, so we'll be locking this thread if there's still no update within 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread here in the Community.
Lovely
