3 weeks ago
I live in a 5-room flat, with a setup of 2 routers and one point (all 2019 version), with a very problematic connection. Normally all have good connection, but quite often (several times a week, sometimes several times a day), the point and sometimes one router simply lose connection, and I have to restart them to regain connection.
The setup is as follows:
So room 4 gets its wi-fi connection through router 2 (as far as I know), which again gets its wi-fi connection from router 1. Normally the connection is good (green in the app, good speed), but as said above, they lose connection all-too often.
I would be grateful for any tips for improving this, or anything I can check.
Thanks.
2 weeks ago
Hi cptFracassa,
Thanks for posting in the community!
It sounds really frustrating that your Nest WiFi connection drops frequently, requiring you to reset and reconnect devices. Here are some tips that might help improve stability:
Following these steps should help improve your Nest WiFi stability. Let me know if you continue to experience connection drops after trying these suggestions. If you have any further questions, feel free to ask!
Nery.
