12-31-2022 07:29 AM
Yes, I know the speed will vary depending on 4G LTE signal but my problem is this: The devices I have connected to the Google WIFI mesh test differently then when running the test through the Google Home app directly from the router. For instance, I run the speed test from the Home App, I get 48Mbps up, 13Mbps down. Then run the test from a laptop connected to the router and I get 0.47 Mbps up and 0.08 Mbps down. I just dont understand why the speeds would be so drastically different.
12-31-2022 08:31 AM
Have you put the Netgear M1 in bridge mode? Could be a double NAT related issue. Both the Netgear and Nest Wifi will probably do QoS too, better cut that down to one box only.
More on double NAT:
01-01-2023 06:55 AM
Thanks for the reply. I will try and figure out how to do that.
01-01-2023 08:27 AM
Well I was able to get the M1 in bridge mode and everything works the same... still very slow speeds on connected devices. Sometimes restarting the M1 fixes it for several days but this time it is not.
01-01-2023 08:37 AM
Alright. There's no settings available to us when it comes to QoS on Nest Wifi. The built in automatic fq_codel QoS mechanism probably does not adjust very well to variable bandwidth.
I'd give Nest Wifi a day or two after you put the modem in bridge mode, to see if it adjusts. Else, get some other router than Nest Wifi where you can control or disable QoS all together.
01-04-2023 06:45 PM
01-05-2023 10:06 AM
Yes the issue is still there. The speeds at the M1/MR1100 (used as modem) are normal but devices connected to the Google Wifi get about 1% of the speed. I have the M1 in IP passthrough mode and the Wifi on it is off.
01-05-2023 11:25 AM
Hey there Jared,
Give these steps a try:
Let us know how it goes.
Mel
01-06-2023 12:52 PM
Thanks Mel.
I tried your suggestions and get the same result. Speed test on Google Home app get 50Mbps, speed test on connected device (ie. smart tv, laptop) gets 3.8Mbps.
01-06-2023 02:09 PM
Hi Jared,
I'm sorry to hear that you're still having an issue with your Google Wifi. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Mel
01-09-2023 04:59 PM
Hey Jared-E,
We got your form — thanks for filling it out. Our support team has already sent you an email and they're just waiting for your update.
Also, please continue the conversation there as this thread will be locked after 24 hours.
Abi
