How to connect my new Starlink device to my Goggle mesh system?
Elliot
Hi – I just installed a new Starlink dish and router. I am receiving a good signal and the Wi-Fi close to the Starlink router is good. But I’d like to connect to the Google mesh router and Wi-Fi points in my house.
Should I disconnect the Goggle router from the modem supplied by my ISP and just eliminate the Goggle router from the set up? Will the two remaking WiFi points in the mesh system talk to the Starlink router?
I am a novice at all this. Thanks for your help!
Hi I am trying to connect my new Starlink set up with the Google mesh system I have in my home. Should I just ignore the Google router that has been connected to the modem supplied by my ISP?
can I connect the two Google mesh points to Starlink for better coverage in the house?
thanks!
8 REPLIES 8
You need to order the Ethernet adapter from the Starlink website. This will put the Starlink Router into bridge mode and it will also provide an RJ45 port so you can connect it to your router via a patch cable.
EdwardT
@Patrick, thanks for the help!
@Elliot, how's it going with your Google Wifi? Still need our help?
Edward
Oh they are Dash I have the same issue. I did purchase the Starlink ethernet adapter and I am trying to simply plug in my Google model H2D to the Starlink adapter that is now connected to the Starlink router. I disabled the built in starlink router so that Google could do its thing and nothing happens. Can the H2D theoretically connect to the Internet or do I need an additional Google device to make this all work?
EdwardT
@CarrieMiller, I'm sorry to hear that you're having an issue with your Google Wifi. Could you tell us more about what's happening? Are you getting any message when you try to set up your Google Wifi?
Edward
So I haven't yet tried setting it up as a new network. When I plug it in, it does broadcast that the network is available but it cannot connect to the internet.  I have the Starlink ethernet adapter and I've tried it both with the Starlink router disabled and also without disabling it - both ways, the network says "no internet".  Next step, set it up as a brand new network?
EdwardT
Hi CarrieMiller,
I'm sorry for the late reply. Just checking back in. Have you tried setting it up as anew network? Looking forward to your response.
Edward
EdwardT
Hi CarrieMiller,
Edward
EdwardT
Hi CarrieMiller,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
