04-02-2025 10:22 AM
My Alienware laptop does have a strong connection to the WiFi. All drivers on the PC are up to date. I've also tried disconnecting/reconnecting. I don't seem to have a problem with other devices. I know a possible fix is moving the laptop to a different band/channel, but it doesn't appear I have that option. Thank you in advance!
04-02-2025 05:21 PM
How far is your laptop from the nest wifi point ? Does the weak signal happen on any other networks ? There is a ton you have to look at here.
04-04-2025 06:50 AM
I have a mesh system with a WiFi Point on every floor. When I noticed this issue, I was only 6 feet from one of the WiFi points. I don't have this issue with other devices. For some reason, the system is not prioritizing my laptops in terms of signal strength
