09-20-2023 12:22 PM
I have for several years used a Google mesh system to extend my wifi signal & it has always worked great. However, I am now have connectivity issues with the nest unit farthest from my modem ("Family Room"). I.e. weak signal, devices default to 2.4G rather than 5G or to %G w/ "no internet." I have run the mesh connection test on my Google Home app & it says all connections are "great." However, when I place my iPhone directly next to the Family Room unit the wifi signal strength doesn't increase (sometimes it actually decreases!). All this started when I recently upgraded to a more powerfuI modem. Is it possible that the mesh isn't jibing with the new modem? Or could it be that the mesh system is just getting old and worn out (I've had it for several years). Any thoughts?
10-04-2023 11:00 AM
Hi JCB1,
That certainly isn’t the experience we want you to have and apologies for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Also, do you have any paused devices?
We know that you’ve already tried other options. It would be a pleasure to help you get through this. Kindly try these steps:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
