03-17-2023 08:22 AM
It isn't every day, but it's close. My 2.4GHz devices just lose connection all at once and I have to restart the net work to get them back. This is super annoying, as you can imagine and I am just about ready to throw this piece of crap away. Does anyone have any suggestions?
03-17-2023 02:35 PM
Hey @Möbius .
Sorry to hear you're having this issue. There's a lot of ways this can go so it is going to be a lengthy answer to try to cover all bases.
It is more than likely with the devices and not the Nest Wifi Pro. This article (How Nest Wifi and Google Wifi 2.4, 5 GHz, and 6 GHz bands work ) goes in detail about how the bands work on the device. In short, the 2.4GHz, 5GHz, and 6GHz bands are broadcast, each with varying ranges per established protocols. Devices that want to connect to your network scan for their network band(s) to see if any are available and connect once found and authenticated; if they do not see their network, they will not connect or will disconnect if already connected. Ranges for each band are the maximum and can be affected by interference, and that interference can fluctuate throughout the day. Devices can lack updated or current firmware/software/hardware that is needed to connect to more recent or advanced units too. In other words, the device decides the connection not the router, unless you have advanced settings like schedules set.
Here's a few things to try:
I think the above covers all of what I can think of. I have the Nest Wifi Pro with anywhere from 40-50 devices connected at any given time and a large portion of them are 2.4GHz connected to the internet but I have not had any of the issues you are describing. I have the router upstairs and one point on the opposite side of the house downstairs in an 1800+sq/ft house.
Let me know if any of these resolve it or you still have issues. If you see anything new or not reported yet occur during the troubleshooting, please advise as well as it could point to the cause and resolution.
03-17-2023 05:02 PM
I appreciate your help. The Nest WiFi with 1 point I replaced with this WiFi Pro never had this problem with the same 2.4GHz device that the Pro is having issues with.
03-17-2023 07:10 PM
Hey @Möbius .
It is not uncommon for some devices to have issues when network devices get upgraded. The Nest Wifi is nearly 4 years old now and a lot has changed since then. If the devices having issues are even older than that, it can compound the problems due to compatibility issues. I switched from the original Google Wifi to the Nest Wifi Pro and have a camera that has the same issue you are describing. It ended up that the camera was capable of "working" on the Nest Wifi Pro but the hardware and software were so far out of date in comparison it would disconnect randomly for no reason; I ended up just replacing it with something newer and haven't had any issues since. Not that it is the case always but it can be.
Let me know how the troubleshooting goes. Just curious, what is the device(s) that is having the disconnects?
03-18-2023 05:33 AM
There are over 20 2.4GHz devices on my network. I have my whole house automated with IoT devices that use the 2.4 GHx spectrum. Should I replace all of them?
03-18-2023 08:30 AM
Sorry for the confusion. I was just using my situation as an example.
Check what I suggested in the initial response. If you have that many devices doing the same thing, the troubleshooting steps should help narrow the cause down.
03-18-2023 07:52 PM
It seems there are a lot of similar problems with the Wi-Fi pro units. I think Google support is completely wrong trying to blame your other devices. With all the similar complaints, the issue is likely the Google Wi-Fi pro
03-18-2023 07:53 PM
At my place it drops all devices including wired ones as well
03-19-2023 05:33 AM
Yeah, never had someone blame other devices. If the WiFi Pro says it supports 2.4 GHz devices, it should support them 100% and it clearly doesn’t. I’m done here. Going to contact Google directly.
03-21-2023 11:15 PM - edited 03-27-2023 11:58 PM
Thanks for lending a hand, @PatrickP_Viking.
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
03-25-2023 11:17 PM
Abi
03-26-2023 11:36 PM
Hello again folks,
Abi
